Defining a Parameter Study#
A parameter study is a systematic way to vary several model parameters and have the system automatically run one or several analyses for each combination of parameters.
For instance, you may want to know how the forces affecting a joint prosthesis depend on the implanted position. Or you may be interested in finding the standing posture by which you can hold a heavy box as easily as possible between your hands. Or how the position of a handle influences the muscular effort of operating it.
Or you may be interested in knowing how the seat height and horizontal position influence the muscle effort and metabolism of the rider. This is precisely what we shall do in this tutorial. To make life a bit easier for you, we have prepared a bicycle model you can download and play around with. Please click here to download the zip fileOptimBike.zip and unpack it to some pertinent place on your hard disk.
The bicycle model is pretty much the 2D Bike that you may know from the AnyBody Managed Model Repository.
../_images/bike2D.png
As you can see the model is very simple. It has two legs and a pelvis that is rigidly fixed to the seat. The feet are attached to the crank mechanism, and the crank is loaded by a sinusoidal torque and constant angular velocity producing a mean mechanical output of 165 W. It has a total of 18 muscles - nine on each leg. You can control the design parameters of the bicycle and the way the rider propels the pedals by means of the variables at the top of the main file. It might be a good idea to play a bit around with the variables and run some analyses. Try, for instance, to raise and lower the seat. Notice that if you raise the seat more than a few centimeters, the model has trouble reaching the pedals. This is really a kinematical problem, but it causes momentarily very high muscle activities and, if you raise the seat further, makes the kinematical analysis break down because the feet lose the contact with the pedals.
The crank torque profile of a bicycle rider changes when the set is moved horizontally because the location of the cycle’s dead center changes. To account for this, a special feature has been set up in this model to adjust the phase shift of the crank torque profile to the seat position such that the minimum crank torque occurs when the pedals point towards the hip joint regardless of where the saddle is positioned.
Some General Terminology#
Before we proceed with the definition of a parameter study it might be useful to introduce the terminology used by AnyBody for parameter and optimization studies:
  • A design variable is an independent parameter controlling some aspect of the model, for instance the seat height, the pedal length, the pelvic angle, the crank torque variation, the cadence, the strength of a muscle, and so on. In short, just about any property you can set in the AnyScript model. A design variable is always a single number and it must be associated with upper and lower variation limits, but it is allowed to construct the model such that many properties depend on each variable. For instance, you might want to define a variable controlling the soleus muscle strength and then let the soleus muscle in both legs depend on it. In this way you can distinguish between dependent and independent parameters, and only independent parameters can be used as design variables. The AnyScript class defining a design variable is called AnyDesVar.
  • A design measure is a dependent parameter that results from an analysis with given values of design variables. Typical examples would be the maximum muscle activity, the metabolism, the mechanical work, the mechanical power generated by a specific muscle, or the force in a joint. The AnyScript class for definition of design measures is the AnyDesMeasure.
These two classes are common to parameter studies and optimization studies, so the two types obviously share several concepts. Let us proceed with the definition of a parameter study. Actually, both these studies come from the same family of classes having the AnyDesStudy as common parent; we commonly refer to these studies as design studies. Within this kinship, they also share the definition of the “analysis” to be performed when evaluating the design measures for a certain set of design variables. The “analysis” is in fact an AnyScript operation (AnyOperation), called Analysis, which is a member of all design studies. To state an optimization or a parameter study properly, the design variables, the design measures, and the analysis must all be defined.
Definition of a Parameter Study#
../_images/class_insert.png
A parameter study is as the name indicates a study. Therefore its natural position in the model is below the existing AnyBodyStudy. We can insert a new parameter study by means of the object inserter mechanism from the class tree. Place the cursor below the definition of the AnyBodyStudy Study, click the Classes tab in the tree view, locate the AnyParamStudy, right-click, and insert a template of the class. You should get the following result:
AnyBodyStudy Study = {
  tEnd = Main.BikeParameters.T;
AnyParamStudy <ObjectName> =
  //LogFile = ;
  /*Analysis =
  Settings =
  Echo = On;
  ModelSceneUpdate = On;
  //AnyOperation &<Insert name0> = <Insert object reference (or full object definition)>; You can make any number of these objects!
  nStep = ;
  AnyDesVar &<Insert name0> = <Insert object reference (or full object definition)>;
  //AnyDesVar &<Insert name1> = <Insert object reference (or full object definition)>; You can make any number of these objects!
  AnyDesMeasure &<Insert name0> = <Insert object reference (or full object definition)>;
  //AnyDesMeasure &<Insert name1> = <Insert object reference (or full object definition)>; You can make any number of these objects!
 As you can see, this requires a bit of additional specifications and general tidying up:
AnyParamStudy ParamStudy =
  Analysis =
  nStep = ;
Here’s a brief explanation of the different components of a parameter study:
Parameter
Function
Analysis
This is a specification of the operation(s) to perform to provide the data we are studying in the parameter study. This will typically be an InverseDynamicAnalysis operation, but it could also be simply an evaluation of some mathematical expression, or it could be a combination of multiple operations, for instance various calibrations followed by an inverse dynamic analysis.
nStep
This is a specification of how many steps to evaluate in the parameter study for each parameter.
AnyDesVar
The study must declare at least one of these. It is the parameter(s) that are varied in the study and for combinations of which the model is analyzed. You can define as many as you like, but please beware that the number of analyses in the parameter study is the product of steps for each AnyDesVar, so the time consumption grows exponentially with the number of AnyDesVars.
AnyDesMeasure
Each of these objects specifies a property that is the result of the analysis and which must be collected for further inspection as the study proceeds. You can define as many of these as you like.
Let us insert the necessary specifications to perform a parameter study on the saddle position of the bicycle:
  Analysis = {
   AnyOperation &Operation = ..Study.InverseDynamics;
As you can see, this is a pointer to the inverse dynamic analysis of the existing AnyBodyStudy in the bicycle model. This specification simply means that to evaluate the parameters we want to investigate in this parameter study, we must execute the analysis of the bicycle. This may seem obvious in a simple model like this one, but many AnyScript models contain multiple studies and each study contains multiple operations.
The next specification deals with the parameters to vary:
  Analysis = {
  nStep = ;
  AnyDesVar SaddleHeight = {
    Val = Main.BikeParameters.SaddleHeight;
    Min = 0.61;
    Max = 0.69;
  AnyDesVar SaddlePos = {
    Val = Main.BikeParameters.SaddlePos;
    Min = -0.22;
    Max = -0.05;
Please notice here that we have removed the ‘&’s that were inserted in the template in front of the variable names. Instead of pointing at AnyDesVars defined elsewhere we include the entire definition right here in the study, and this is actually the usual way to do it.
Each AnyDesVar gets three properties set. The first one is called Val and is simply set equal to an existing parameter in the model. The best way to understand this statement is to think of Val as a reference variable that is equalized in the first case with the SaddleHeight, which is a parameter defined at the top of the main file. At any time in the parameter study, Val will be equal to the saddle height as one should expect from the assignment. But in this special case, the assignment also goes the other way: It lets the parameter study control the value of what is on the right hand side of the equality sign, in this case the SaddleHeight parameter. We have similarly defined a second parameter, SaddlePos, which allows the parameter study to vary the horizontal saddle position. This two-way linkage between Val and another variable in the model implies certain restrictions on what assignments AnyScript allows for this particular case. The referred variable must be a scalar quantity, i.e. either a scalar or an element of a larger structure (e.g. vector or matrix). Secondly, it must be an independent scalar quantity, i.e., it cannot depend (by expressions) on other variables; otherwise there would exist an ambiguity.
The next step is to define the properties we wish to study, i.e. the dependent parameters or “design measures” of the model. As you know, after running an operation from a study the results are available in the Output branch of the tree view of the operation and they can be plotted, dumped and copied to the clipboard and so on. Now we are defining a study that will execute operations from other studies and assemble the results for later investigation. We might even want to make mathematical operations on these results, combine results from different operations, and so on. To do this we must refer to the result we wish to store for further processing. There is just one semantic problem: The results do not exist until we have performed the analysis, but we must refer to them already when we author (and load) the model.
To solve this problem we must go back to the AnyBodyStudy Study, from where we want to lift the results, and declare an object that will allow us to refer to computational results before they are actually made. The object is of class AnyOutputFun, and we shall add it to the existing AnyBodyStudy:
  AnyOutputFun MaxAct = {
     Val = .MaxMuscleActivity;
This allows us to refer to Study.Output.MaxMuscleActivity before it actually gets created.
AnyOutputFun is actually a class of mathematical function that returns the output (when existing) associated with the Val member. So here we have created a function called MaxAct that takes no arguments and returns the output data for .MaxMuscleActivity. Notice that AnyOutputFun must be declared inside a study in order to resolve the association with the output data structure of the particular study.
We can now use the output function, MaxAct(), in our design measure simply by calling the function in the assignment of the Val member of the AnyDesMeasure:
    Min = -0.22;
    Max = -0.05;
AnyDesMeasure MaxAct = {
 Val = max(..Study.MaxAct());
Notice the definition. The MaxAct function for each InverseDynamics operation returns a vector of maximum muscle activities in the model. The vector has as many components as the study has time steps, i.e. 50 in the present case. In the definition of the AnyDesMeasure we want to save only the largest value of each of the vector, so we wrap the call of the MaxAct function in another max() function. AnyScript gives you a number of such data processing functions and we shall study others further down. Please refer to the reference manual for further details.
One thing is missing before we can try the whole thing out: We must specify how many steps we want the parameter study to perform for each parameter. As in AnyBodyStudies this is done by the nStep variable, but where nStep in an AnyBodyStudy is an integer variable, it is a vector with one component for each AnyDesVar in an AnyParamStudy. We shall be modest at first and choose only five steps in each direction. And so, the final AnyParamStudy looks like this:
AnyParamStudy ParamStudy = {
  Analysis = {
  nStep = {5,5};
      Min = 0.61;
      Max = 0.69;
      Min = -0.22;
      Max = -0.05;
It is finally time try it out. If you have typed everything correctly, then you should be able to load the model. Then find the Main.ParamStudy.ParameterStudy opertion in the operation dropdown:
../_images/operation_select.png
Make sure you have a Model View window open. With the ParameterStudy select in the operation drop-down click the “Run” botton. You should see the model starting to cycle, and if you watch the vicinity of the saddle carefully, you will see that the hip joint is changing its position on a 5 x 5 grid. With a reasonably fast computer it should take a minute or less to do the 25 analyses after which the computations stop.
If you turn off the model view, the computation should speed up.
Congratulations! You have completed your first parameter study. Let us investigate the result.
The obvious way to visualize the results of a study with two parameters is as a 3-D surface. The chart view in AnyBody can also do that.
../_images/anychart1.png
The toolbar of this window indicates a kinship with the Model View window. Indeed, if you select the rotation button in the toolbar and drag the mouse with the left button down inside the coordinate system you will notice that the system rotates just like an ordinary Model View. Now, expand the Model node in the tree until you can click the ParamStudy->Output->MaxAct->Val property. The coordinate system automatically attains a second abscissa axis and you can see a nice surface like this:
../_images/anychart2.png
The surface shows the maximum muscle activity over the cycle for each of the 25 combinations of parameters and provides a very nice overview of the behavior of the model. The surface reveals that the highest and most backward position is the best. Why not try higher and more backward, then? It is very simply to do:
    Min = 0.61;
    Max = 0.69 + 0.02;
    Min = -0.22 -0.03;
    Max = -0.05;
When you re-run the parameter study, things will go well in the beginning, but towards the end of the 25 combinations you may notice muscles beginning to bulge more and momentarily attain the color of magenta. This is the system’s way of demonstrating that the muscles have been loaded above 100% of their strength. The reason why this happens is that, as the seat rises, the model gets into positions where it is difficult for the feet to reach the pedals. Just before the feet cannot reach the pedals the knee movements are accelerated causing large inertia forces in the system. All this happens a bit more drastically in an ideal rigid body model than it would in real life where joints have a bit of slack, segments are slightly elastic, and the prescribed kinematics may be compromised. You can see very clearly what happens if you go back to the AnyChart View and study the new surface:
../_images/anychart3.png
The surface is now completely dominated by the one combination, which is difficult for the model to do. You can still see the surface shape if you change the scale of the value axis. This and all other settings are available if you click the chartsettings.png button in the toolbar. Doing so will produce a window with a tree view in which you can select ValueAxis->``Max``. Try setting Max to 0.25 and you should obtain the following:
../_images/anychart4.png
What this study reveals is that in terms of muscle activity to drive the bicycle a high seat is advantageous, but there seems to be a very sharp limit where the leg gets close to not being able to reach the pedals, and this should not be exceeded. One additional remark in this context is that this bicycle model has a predefined ankle angle variation whereas a real human can compensate for a higher seat by letting the ankle operate in a more plantar-flexed position.
Before we finish this section, let us take a look at a particularly important feature of AnyScript mathematics: The ability to compute integral properties. AnyBody has a simple way of approximating the metabolism of muscles based on the simulation of each muscle’s mechanical work. Metabolism is technically a power measured in Watt, and the sum of the individual muscle metabolisms will give us an estimate of the total metabolism involved in the bicycling process. It is fairly simple to add up the muscle metabolisms in the AnyBody study:
/// The study: Operations to be performed on the model
  nStep = 50;
  // Useful variables for the optimization
  AnyFolder &r = Main.Model.Leg2D.Right.Mus;
  AnyFolder &l = Main.Model.Leg2D.Left.Mus;
  AnyVar Pmet_total = r.Ham.Pmet+r.BiFemSh.Pmet+r.GlutMax.Pmet+r.RectFem.Pmet+r.Vasti.Pmet+r.Gas.Pmet+r.Sol.Pmet+r.TibAnt.Pmet+l.Ham.Pmet+l.BiFemSh.Pmet+l.GlutMax.Pmet+l.RectFem.Pmet+l.Vasti.Pmet+l.Gas.Pmet+l.Sol.Pmet+l.TibAnt.Pmet;
Notice that we have defined the r and l variables for convenience to limit the size of the expressions. If you run the InverseDynamics Analysis (go on and try!) you will find the new variable mentioned in the list of output, and you can view it in the chart view.
../_images/metabolism_curve.png
The area under this curve is the total metabolism combusted over a crank revolution. To compute this we must introduce two more elements. The first one is an AnyOutputFun as we have seen it before. The purpose of this function is to make it semantically possible to refer to the output of the Pmet_total variable before is has actually been computed:
  AnyOutputFun Metabolism = {
    Val = .Pmet_total;
The second missing element is the actual integration of the function. This we perform in the parameter study where we define the AnyDesMeasure:
  Analysis = {
  nStep = {10,10};
      Min = 0.61;
      Max = 0.69 /*+ 0.02*/;
      Min = -0.22 /*-0.03*/;
      Max = -0.05;
  AnyDesMeasure Metab = {
    Val = secint(..Study.Metabolism(),..Study.tArray);
The secint function performs a numerical integration of the first argument against the second argument. Each argument must be an array and the number of components in the two arguments must be the same.
Notice the other two changes: We have changed the variable limits back to what they were before and we have decided to be a little more adventurous and have specified 10 variable steps in each direction. It is time to run the parameter study again. The new Metab variable is now available in the list under the ParamStudy in the Chart window and can be plotted:
../_images/anychart5.png
We shall return to the capabilities of the Chart view in more detail in the next lesson, which deals with the definition of optimization studies.
