Lesson 1: Using References
AnyScript is really a programming language, and just like any other programming language you can define variables and assign values to them. For instance, you may write
AnyVar a = 10.0;
AnyVar b = a;
Folders are also variables, and a folder definition can go like this:
AnyFolder MyFolder = {
   // A whole lot of stuff inside
However, folders cannot be assigned like a and b above, so the following is illegal:
AnyFolder MyFolderCopy = MyFolder;
In general, you can only do direct assignment of value variables, i.e. variables containing numbers or collection of numbers. This assignment is allowed:
AnyVector aa = {1,2,3};
AnyVector bb = aa;
But folder assignments are not allowed. So how can you refer to large portions of the model in just one assignment operation? The answer is that you can refer by reference, and just about any assignment between variables of compatible type will work:
AnyFolder &MyFolderCopy = MyFolder;
The ampersand, &, in front of the variable name specifies that this is a reference. What it means that MyFolderCopy will just point to MyFolder, so whatever you do to MyFolderCopy will happen to MyFolder. It is as simple as that. A pointer variable takes up very little space in the computer because it does not copy the data it is pointing to.
This demo example illustrates some of the important uses of pointer variables: demo.creatingandreferringtoobjects.any
Next lesson: Lesson 2: Using Include Files.
