Installing Latest AMMR Files#
Here you can find the guide on how to install the latest AMMR files. The files will be located locally, in the Documents folder of each user on your computer. If there are multiple users using your computer, each of them will have to follow this guide.
STEP 1
To get a fresh copy of the AMMR select the “Demo” tab in the AnyBody Assistant window that opens when AnyBody starts:
STEP 2
Then select the “Install the demo repository by clicking this link”.
This installs the repository into your Documents folder (e.g.
~/Documents/8.1.x/AMMR.v4.0.0-beta-Demo). You may keep these files safe on your computer by
copying them to another location. There you can initialise a git repository in
which you can version you models, keep a backup or share them easily with the
community.
Warning
As written before, AnyBody Modeling System comes with a version of AMMR (not necessarily the latest) which you can find in the installation folder of the software. Do not directly use these files for your actual work unless you copy them somewhere else. There is a risk to lose your changes in case AnyBody is reinstalled or updated. You can use these files safely by copying them to your working folder.
