Lesson 1: Joint to Joint Scaling Methods#
This lesson covers five of the scaling laws available in AnyBody:
  • _SCALING_STANDARD_ (scale to a standard size)
  • _SCALING_NONE_ (do not scale)
  • _SCALING_UNIFORM_ (scale equally in all directions; input is joint to joint distances)
  • _SCALING_LENGTHMASS_ (scale taking mass into account; input is joint to joint distances and mass)
  • _SCALING_LENGTHMASSFAT_ (scale taking mass and fat into account; input is joint to joint distances)
ScalingStandard#
This scaling law produces a model with the default parameters for mass and size (corresponding roughly to the 50th percentile European male). It is used by default for non-specific models, or when there is no data available about the modeled subject. This law has no input parameter to modify.
With the AnyBody Modeling System you already have a repository of models available. As a starting point for this tutorial, please find this model from the AMMR:
Applications/Examples/StandingModelScalingDisplay/StandingModelScalingDisplay.Main.any
First, copy the whole folder “StandingModelScalingDisplay” to your working directory. Then open the StandingModelScalingDisplay.Main.any file.
To use the StandardScaling law you do not need to do anything at all; however, for demonstration purposes the scaling law configuration parameter (BM_SCALING) will be set to use the default value:
/*------------- SCALING CONFIGURATION SECTION --------------------*/
// Scaling laws using joint to joint measures
   #define BM_SCALING _SCALING_STANDARD_
//  #define BM_SCALING _SCALING_NONE_
//  #define BM_SCALING _SCALING_UNIFORM_
//  #define BM_SCALING _SCALING_LENGTHMASS_
//  #define BM_SCALING _SCALING_LENGTHMASSFAT_
//  #define BM_SCALING _SCALING_XYZ_
//--------------- END OF SCALING CONFIGURATION -------------------
Now load the model and open a Model View window. You will see the standing model with the standard size.
../_images/ScalingStandardFront.jpg ../_images/ScalingStandardBack.jpg
ScalingNone#
This particular scaling law can be used for the studies, which require the unscaled cadaveric datasets, which were used for the construction of the body parts. Please enable the _SCALING_NONE_ option in order to switch to this scaling law.
The result will not noticeably change as compared to the ScalingStandard, but minor differences can be observed when looking at the actual locations of the muscle attachment sites and so on.
Working with known body part dimensions#
When modelling a specific person with known anthropometric factors, e.g. weight, height, body part lengths, etc., these details need to be incorporated into the model. In this case _SCALING_STANDARD_ and _SCALING_NONE_ are not applicable, since they correspond to predetermined human sizes and weights, which cannot be overwritten.
For these purposes a number of additional scaling laws were implemented, which all share an input mechanism for subject-specific measurements. This mechanism lets the user overwrite the height, weight, fat percentage, and individual segmental measurements or scale factors. This is done like below:
// Example of how to overwrite the default values
//  Main.HumanModel.Anthropometrics.BodyHeight = 1.8;
//  Main.HumanModel.Anthropometrics.BodyMass = 80;
The above line shows how it can be overwritten from, say, the Main folder. We can now easily personalize the model using anthropometric measurements.
Do I need to overwrite all the anthropometric variables?#
No, you do not need to overwrite all the anthropometric variables. The implementation allows you to overwrite only the ones you need. For example, if you only know the body mass and height, you can overwrite only these two variables and the rest will be calculated automatically.
ScalingUniform#
This law allows you to define the total weight of the model and the individual sizes of the bones. The length of each bone is defined as a joint to joint distance and the bone is then scaled in three dimensions proportionally to its length. To use this law you must change the scaling parameter to be _SCALING_UNIFORM_.
In the previous section we showed how this can be done. Please do so, then load the model and have a look at the Model View window. Notice that the body size did not change from the standard scaling version. This is because the default values for segment masses and sizes in this file are the same as the standard values. But if you change them, the model will scale according to your specifications.
Let us try to change the mass of the body. First, inspect the BodyMass variable in the Model Tree window. You can find it at Main.HumanModel.Anthropometrics.BodyMass. The default value is 75 kg.
Try changing it to 90 kg by adding the following to your main file:
Main.HumanModel.Anthropometrics.BodyMass = 90;
Now load the model again. Once again the size of the body did not change. In the ScalingUniform law, the BodyMass parameter controls the mass of the segments but not their sizes. As shown previously the overall body mass is distributed to each segment.
So the BodyMass parameter only controls the segment masses. The size of the model is controlled by another list of variables defining the lengths of the different bones. The length of each segment can be set independently, for example we can increase the length of the thigh by adding the following line to the main file:
Main.HumanModel.Anthropometrics.SegmentDimensions.Right.ThighLength = 0.626;
Load the model again and have a look at the Model View window. The femur bone is now bigger. It has been scaled uniformly in 3 directions according to the defined length. Notice that we only changed the size of the femur and not the other bones, so the femur looks unreasonably big compared to the rest of the body. To avoid results such as this, it is important to feed those variables with consistent data rooted in real anthropometry.
Large Femur Front
Let us apply a more reasonable size. Please change the default values to the following set of consistent measures:
Main.HumanModel.Anthropometrics.SegmentDimensions.PelvisWidth = 0.180;
Main.HumanModel.Anthropometrics.SegmentDimensions.HeadHeight = 0.169;
Main.HumanModel.Anthropometrics.SegmentDimensions.TrunkHeight = 0.754;
Main.HumanModel.Anthropometrics.SegmentDimensions.Right.UpperArmLength = 0.405;
Main.HumanModel.Anthropometrics.SegmentDimensions.Right.LowerArmLength =0.316;
Main.HumanModel.Anthropometrics.SegmentDimensions.Right.ThighLength = 0.548;
Main.HumanModel.Anthropometrics.SegmentDimensions.Right.ShankLength = 0.551;
Main.HumanModel.Anthropometrics.SegmentDimensions.Right.FootLength = 0.243;
Main.HumanModel.Anthropometrics.SegmentDimensions.Left.UpperArmLength = 0.405;
Main.HumanModel.Anthropometrics.SegmentDimensions.Left.LowerArmLength =0.316;
Main.HumanModel.Anthropometrics.SegmentDimensions.Left.ThighLength = 0.548;
Main.HumanModel.Anthropometrics.SegmentDimensions.Left.ShankLength = 0.551;
Main.HumanModel.Anthropometrics.SegmentDimensions.Left.FootLength = 0.243;
ScalingUniformFront
When you reload the model you should see a tall body and with proportionate sizes of the segments. If you can’t see the difference from the standard size model, notice how the feet are now sticking down below the reference frame.
It should be obvious that this type of scaling requires good anthropometric data to give reasonable results. But such data is not always easily available. To help with this, the default values of the _SCALING_UNIFORM_ law is implemented in a way that it only takes as input the body mass and the body height and subsequently scales all the segment lengths uniformly according to the defined body height. This may not give you a model where each bone matches a given subject, but it can be a reasonable estimate in cases where only the overall mass and height of the body is known. Try to comment out these lines again:
//Main.HumanModel.Anthropometrics.SegmentDimensions.PelvisWidth = 0.180;
//Main.HumanModel.Anthropometrics.SegmentDimensions.HeadHeight = 0.169;
//Main.HumanModel.Anthropometrics.SegmentDimensions.TrunkHeight = 0.754;
//Main.HumanModel.Anthropometrics.SegmentDimensions.Right.UpperArmLength = 0.405;
//Main.HumanModel.Anthropometrics.SegmentDimensions.Right.LowerArmLength =0.316;
//Main.HumanModel.Anthropometrics.SegmentDimensions.Right.ThighLength = 0.548;
//Main.HumanModel.Anthropometrics.SegmentDimensions.Right.ShankLength = 0.551;
//Main.HumanModel.Anthropometrics.SegmentDimensions.Right.FootLength = 0.243;
//Main.HumanModel.Anthropometrics.SegmentDimensions.Left.UpperArmLength = 0.405;
//Main.HumanModel.Anthropometrics.SegmentDimensions.Left.LowerArmLength =0.316;
//Main.HumanModel.Anthropometrics.SegmentDimensions.Left.ThighLength = 0.548;
//Main.HumanModel.Anthropometrics.SegmentDimensions.Left.ShankLength = 0.551;
//Main.HumanModel.Anthropometrics.SegmentDimensions.Left.FootLength = 0.243;
Now it is easy to scale the body down to represent a small person. Use thefollowing line to set the body height to 1.65 m and the body mass to 60 kg:
Main.HumanModel.Anthropometrics.BodyHeight = 1.65;
Main.HumanModel.Anthropometrics.BodyMass = 60;
When you load the model you will see all the segments automatically scaling down. The mass is also scaled, but as we said previously this is not visible graphically with this scaling law.
Scaling based on length and mass#
This law scales the size of the body according not only to the segment lengths but also to the segments masses, so unlike the ScalingUniform law it provides the opportunity to define tall and skinny people or small and squat people. Like in the ScalingUniform law, the total body mass is defined by the variable BodyMass. Just as previously, this total mass is then divided between the segments by means of coefficients, but the size scaling is different. Let us investigate it. In the main file, please choose the ScalingLengthMass law and switch back to the AnyMan file:
//#define BM_SCALING _SCALING_UNIFORM_
In the Main file, switch back the segment length values to the initial ones (by outcommenting the added lines) and increase the body mass to 110 kg:
Main.HumanModel.Anthropometrics.BodyMass = 110;
Load the model and look at the Model View. Our model looks strange! The body is deformed and looks a bit like a Neanderthal.
../_images/ScalingLengthMassFront.jpg ../_images/ScalingLengthMassBack.jpg
What really happens is that the ScalingLengthMass law scales the sizes of the segments according to their masses, but only in two directions. The third scaling direction is controlled by the segment length variables. Unlike in the ScalingUniform law, the segment length variables just control one scaling direction and not the two others.
So to have a normal-looking model we have to adjust segment mass and length simultaneously. As the mass we defined is 110 kg, a height of 1.98 m could be reasonable:
Main.HumanModel.Anthropometrics.BodyHeight = 1.98;
../_images/ScalingLengthMassCorrectFront.jpg ../_images/ScalingLengthMassCorrectBack.jpg
When you load the model you will see a more Homo sapiens-looking figure corresponding to a large 110kg and 1.98 m person.
We mentioned at the beginning of the tutorial that the muscle strength is also scaled. It is time to have a look at it and compare muscle forces from different scaled models. To do so we need a body with muscles. Please add the muscles by commenting out the following section of the general configuration block in the BodyModelConfiguration.any file:
// #define BM_LEG_MUSCLES_RIGHT OFF
// #define BM_LEG_MUSCLES_LEFT OFF
// #define BM_ARM_MUSCLES_RIGHT OFF
// #define BM_ARM_MUSCLES_LEFT OFF
// #define BM_TRUNK_MUSCLES OFF
We also need to add some forces to the model in order to make it react and see muscle activity. This can be done by adding the following lines to the Environment.any file. This piece of code creates a force of 50 N on each hand and displays it in the model view:
AnyFolder Environment = {
  AnyFixedRefFrame GlobalRef = {Origin = {0.0,0.0,0.0};};
AnyForce3D RightHandLoad = {
  F = {0, -50, 0};
  AnyRefFrame &Hand = Main.HumanModel.BodyModel.Right.ShoulderArm.Seg.Glove;
AnyForce3D LeftHandLoad = {
  F = {0, -50, 0};
  AnyRefFrame &Hand = Main.HumanModel.BodyModel.Left.ShoulderArm.Seg.Glove;
AnyDrawVector DrawRightLoad = {
  Vec = .RightHandLoad.F*0.015;
  PointAway = On;
  GlobalCoord = On;
  Line = {
    Style = Line3DStyleFull;
    Thickness = 0.01;
    RGB = {0, 0, 0};
    End = {
      Style = Line3DCapStyleArrow;
      RGB = {0, 0, 0};
      Thickness = 0.025;
      Length = 0.025;
  AnyRefFrame &Hand = .RightHandLoad.Hand;
AnyDrawVector DrawLeftLoad = {
  Vec = .LeftHandLoad.F*0.015;
  PointAway = On;
  GlobalCoord = On;
  Line = {
    Thickness = 0.01;
    RGB = {0, 0, 0};
    End = {
      RGB = {0, 0, 0};
      Thickness = 0.025;
      Length = 0.025;
  AnyRefFrame &Hand = .LeftHandLoad.Hand;
AppliedForcesFront
We are now ready to run an inverse dynamic analysis with our large 110kg model. Please load the model and run the RunApplication operation from the Operations tab. Then open a chart window to investigate the results. By browsing your way to the MaxMuscleActivity in the folder Main.Study.Output you should get the following value:
MaxMuscleActivity198cm110kg
We will now try to model a small person to compare his muscle activity with the one we have just plotted. Let us enter the parameters for a 65kg and 1.70 m person:
Main.HumanModel.Anthropometrics.BodyHeight = 1.70;
Main.HumanModel.Anthropometrics.BodyMass = 65;
We can load the model, run the inverse dynamics analysis and check the resultant value.
MaxMuscleActivity170cm65kg
For the same load on the hands (50 N) the tall heavy model has a muscle activity of 53.3 %, whereas the short model reaches 67.7 % of muscle activity. So our small model is definitely weaker than the tall one.
ScalingLengthMassFat#
Most scaled models used for practical investigations use the ScalingLengthMassFat law. It works exactly like the ScalingLengthMass but with an additional parameter: It takes the fat percentage of the body into account. The argument is that the fat percentage adds to the mass of each segment and in the ScalingLengthMass law would lead an estimation of more muscle tissue rather than fat tissue. So the fat percentage in this scaling model does not modify the mass or the size of the body. It is only used to calculate the strength of the muscles. Between two persons of similar segment masses, the one with higher fat percentage will have less muscle strength, because the volume otherwise occupied by the muscles is replaced by inactive fat.
So the mass and size scales are controlled as in the ScalingLengthMass model by the BodyMass variable and all the segment length variables respectively. The fat percentage is controlled in concert by the variables BodyHeight and BodyMass. These two variables are used to calculate the BMI (Body-Mass Index), and the BMI is used to calculate the fat percentage of the body according to Frankenfield et al.[1]
// Default values for the fat percentage found in (ammr\Body\AAUHuman\Scaling\DefaultAnthropometrics.any)
AnyVar BMI = AnthroData.Body_Mass/(AnthroData.body_height*AnthroData.body_height);
AnyVar FatPercent = (-0.09 + 0.0149*BMI - 0.00009 *BMI*BMI)*100; //Estimation from Frankenfield et al. (2001) valid for men
Obviously, it is important to input the correct height of the body when using this law. Please notice, however, that it is very easy for the user to substitute the formula for the fat percentage by another equation or possibly by a fixed number for modeling of a particular individual for whom the fat percentage has been measured directly.
The resultant value for the fat percentage is then directly used to compute an estimate of the strength of each muscle in the model.
This advanced strength scaling makes a significant difference for the model that is short and heavy. The ScalingLengthMass law tends to over-estimate the strength of those models, because they often have a high fat percentage that is not taken into account by the law.
We will try to illustrate this by plotting the muscle activity of the same short and heavy model with both ScalingLengthMass and ScalingLengthMassFat laws. We will begin by adjusting the anthropometrics to match a 90kg and 1.70 m person:
Then please load the model and re-run the application. Notice that we should still be using the ScalingLengthMass law. You should now get the following value for the maximum muscle activity.
MaxMuscleActivity170cm90kgLM
The next step is to run an analysis with the same body but with the ScalingLengthMassFat law:
Once again load the model and run the inverse dynamics analysis by executing the RunApplication operation. We should get the following results:
MaxMuscleActivity170cm90kgLMF
If we compare these two activity values, the difference is clear. The ScalingLengthMassFat law is increasing the muscle activity by approximately 16 % in this case, from 50 % to 66 %. This shows the limits of the ScalingLengthMass law for extreme cases. ScalingLengthMassFat is able to cover a wider range of cases while keeping its accuracy.
This completes scaling Lesson 1: Joint to joint scaling methods.
