Lesson 1: Using real data#
In biomechanics, we often want to make our models move as we have measured in the laboratory and the measurement technique would often be tracking of optical markers in space by means of synchronized cameras.
There are many such systems available commercially, but a common feature of most of the systems is that they are capable of saving data on a standard format called a C3D file.
A C3D file contains data of the spatial trajectory of optical markers fixed to the object whose motion we want to record. The file can also contain analog data such as force platform measurements or EMG. AnyBody can read the data from a C3D file directly.
The AnyBody Modeling System offers you virtually unlimited ways of doing things, and probably more than the average user can comprehend.
The AnyBody Model Repository (> 2.0), contains some pre-cooked examples which are easy to drive with your own data and which contain some really neat features for data processing.
Make sure you have installed your own copy of the AnyBody Model repository (AMMR). See the Getting Started Tutorial for instructions on how to install it.
  1. Go to the folder Application/MocapExamples/Plug-in-gait_Simple.
  2. Open LowerExtremity.main.any in the AnyBody Modeling System
This is a gait model comprising only the lower extremities and the necessary part of the upper body for attachment of muscles. The model is based on a C3D file with “Plug in Gait” marker protocol, and three force platforms. You can easily modify this to any other movement, simply by importing a different C3D file to drive the model with.
Code example 1: LowerExtremity.main.any#
 1#include "../libdef.any"
 2
 3// Enter and edit Trial Specific Data in this file:
 4#path MOCAP_TRIAL_SPECIFIC_DATA "Setup/TrialSpecificData_LowerExtremity.any"
 5
 6// Enter and edit Subject-Spcific Data in this file:
 7#path MOCAP_SUBJECT_SPECIFIC_DATA "Setup/SubjectSpecificData.any"
 8
 9// Enter and edit Lab-Specific Data in this file:
10#path MOCAP_LAB_SPECIFIC_DATA "Setup/LabSpecificData.any"
11
12// Include the AnyMoCap Framwork
13#include "<ANYMOCAP_MODEL>"
The model defines three sections/files which must be customized.
  • TrialSpecificData.any.
  • SubjectSpecificData.any
  • LabSpecificData.any
Following this structure is not strictly necessary, but good practice. Finally, on line 13 we include the AnyMocap framework or base model.
Now please load the model and open up a new Model View. You should see the following model:
View of the model
The model consist of number of operations which must be executed in the correct order. The flow of the model is illustrated in the following figure.
../_images/flow.png
Fig. 2 Illustration of the three processes for the Mocap models. Parameter identification, Marker tracking, and Inverse Dynamic analysis. See Lund et al. 2015 for a detailed dicussion on different approches to MoCap analysis.#
Parameter identification#
If you look closely at the model view, you can see that the skeleton is equipped with markers and if you zoom in a little, you can also see that the markers carry small coordinate systems with red and green arrows.
Close up view of leg
These are the marker points defined on the human body, and the red and green arrows designate directions in which the marker position is fixed versus free to be optimized. A free marker position is one that is not well-known by the clinician.
So why would we be in doubt about the position of a marker that we have placed? Well, clinicians place markers on the skin at an unknown distance from the bone, and even when a marker is placed on a bony landmark just below the skin, we are never quite sure which point that corresponds to in the bone’s local coordinate system. If we get those points wrong, the resulting motion of the model will also be inaccurate.
So the green arrows designate directions in which we have the greatest uncertainty about whether the marker is placed in the model as it was in the experiment. The good news is that we can optimize those marker placements exactly as we are going to do in lesson 4.
The model is set up to do this automatically, and if you are happy with the choice that has been made, you need not do anymore.
If you use a different marker protocol, or customize what is optimized you will need to modify the marker protocol. In this example, the marker protocol is defined in the file Setup/MarkerProtocol.any. In the interest of simplicity, we shall postpone the discussion of the marker protocol setup.
In addition to the marker coordinates, the model considers the segment lengths to be variable, so the computation we are about to do will also automatically figure out how long the segments are, and thereby where the joints are placed.
Pretty much any parameter in a model can be made variable in the optimization study. But some parameters will be determined well by the marker trajectory data and not all parameters can be determined at the same time because the mocap data only contains limited information.
For instance, if the model has no movement about a specific joint, then it is not possible to get information about the location of that joint or about the lengths of adjacent segments from the marker data.
Running Parameter identification#
Without further ado, let us perform the optimization:
Find the Main.RunParameterIdentification in the operations dropdown, and run it.
Opertions RunModtionAndParameterOpt
You will see the model walking repeatedly over the force platforms, sometimes slowly and sometimes a bit faster depending on the speed of your computer and the progress of the computation.
The process speeds up significantly if you switch off the Model View ModelViewOff.
When operation is done you will see the line Optimization converged in the Output windows and final lines will be:
#### Macro command : SaveToFile(1:1)> classoperation Main"Save Values"--file="Output/Plug-in-gait.anyset"
Saving modified values to 'Output/Plug-in-gait.anyset'
It means that things have gone fine, the optimization has converged, and the optimized values of the variable parameters have been saved on a text file for later use.
Before we continue, let us ponder for a moment when it is necessary to perform this optimization. The results of the optimization in summary are the following:
  1. Updated anthropometrical parameters.
  2. Updated marker locations.
Within a brief time we can safely presume that the first is constant for a particular test subject. This means that if we have once and for all determined and saved the anthropometrical parameters of this subject, then we probably need not include them in the optimization again.
We can usually presume that the marker locations on the body are constant within a given trial or series of trials performed with the same subject with the same markers attached. However, if the markers have been detached or relocated, then obviously the optimization of marker positions must be done again.
However, for most cases, the computational effort of performing the optimization with all the parameters is modest, to the casual user may elect to simply redo the full optimization for each trial as we shall do later in this tutorial.
Marker tracking and Inverse dynamics#
Let us proceed with the kinematic analysis. As we will see later in Lesson 2: Using motion capture data marker based models usually require an over-determinate kinematic solver to handle the excess in information that the optical markers provide. The over-determinate solver in AMS works great, but it will calculate velocities and accelerations numerically. That has some performance issues when running inverse dynamics analysis. To overcome this problem, the MOCAP analysis is split into a two-step procedure, as illustrated on figure Fig. 2, separating the Marker tracking from the Inverse dynamic analysis.
The overdeterminate kinematic analysis solves the model for positions, and stores the joint angles as function of time. This step is the “Marker tracking” step in figure Fig. 2. These joint angles are then used in the second step with the determinate kinematic solver in the inverse dynamic analysis.
In the Model the Marker tracking and Inverse Dynamics are combined into a single operation called Main.RunAnalysis.
Operations tree
The operation contains everything that is necessary to run the analysis: It loads the optimized model parameters that were saved previously; it run the marker tracking, and if necessary performs calibration movements to adjust the tendon lengths to the lengths of the bones; and finally executes a dynamic analysis to determine forces in the system. Run the analysis by selecting it from the Operations dropdown, and click “Run”.
After the kinematic Marker tracking, the muscles are switched on, and the inverse dynamic analysis starts. This step will usually be the slowest, due to the very high amount of detail of the model, requiring the computer to continuously calculate forces in more than 300 muscles. When the analysis is finished, you can open up a Chart view and investigate the results, for instance the hip joint reaction forces:
Chart Fout
Importing new motion data#
So we have seen the model optimize its parameters and we have seen it perform a dynamic analysis on existing data that somebody else has defined. But here comes the real point of the application:
Processing a different motion is exactly the same
All we have to do is to replace the C3D file containing the motion data. The MoCapModel folder already contains a few C3D files located in the subfolder Input that we can try. All we have to do is to make the model point at a different file. A few lines into the Main file, you find this:
This file contains the settings you typically want to change when switching trials.
Double-click the TrialSpecificData_LowerExtremity.any file name, and the file opens up in a new tab. Then, just a few lines down, refer to the new filename into the model:
// This is the name of the trial c3d file without extension
TrialFileName = "GaitFast_1";
Since this is a new C3D file from a new trial, we also need to run the kinematic optimization again.
Since we have included a new C3D file containing a different amount of frames, we have to adjust the first and last frame of the simulation. This is done in the TrialSpecificData_LowerExtremity.any file, where we have to make the following changes:
// This the C3D frame where the analysis starts
// If not specified it defaults to the first frame of the C3D file
//FirstFrame = .C3DFileData.Header.FirstFrameNo;
FirstFrame = .C3DFileData.Header.FirstFrameNo+5;
// This the C3D frame where the analysis ends
// If not specified it defaults the first frame of the C3D file
//LastFrame = .C3DFileData.Header.LastFrameNo;
LastFrame = .C3DFileData.Header.LastFrameNo-5;
This defines that the simulation starts 5 frames after the first frame in the C3D file and ends 5 frames before the last frame in the C3D file.
We can now load the model and see it moving (without doing the parameter optimization just now). Locate and run the Kinematics (“Marker tracking”) operation in the Operation tree:
Operations, kinematics
The movement seems to work fine and you will notice that this gait pattern is a little different from before. The steps are longer and the posture indicates that this is a person in a hurry.
Model view, marker tracking
Now is the time to run the Main.RunParameterIdentification. It takes a bit of time, and again you can speed up the process by switching off the update of the Model View window. Eventually, the process comes to an end and you get the message:
1.0) Operation Sequence: (Operation: Main.RunParameterIdentification.SaveParameters):
1.0.0) Dummy operation: (Operation: Main.RunParameterIdentification.SaveParameters.placeholder_operation):
1.1.0) Operation Sequence: (Operation: Main.ModelSetup.Macros.Save_parameters):
1.1.50.0) SaveToFile (Operation: Main.ModelSetup.Macros.Save_parameters.SaveToFile):
#### Macro command : SaveToFile(1:1)> classoperation Main"Save Values"--file="GUI_Plug-in-gait_fast.anyset"
Saving modified values to 'Output\GUI_Plug-in-gait_fast.anyset'
Next, we run the combined Marker tracking and Inverse dynamics (Main.RunAnalysis) operation.
Which, after the analysis can provide a new hip joint force profile documenting that faster gait lead to higher hip joint forces.
../_images/charview_higher_hip_forces.png
Using full-body models#
Many motion experiments deal with the entire body as opposed to just the lower extremities. The Model Repository contains another pre-cooked model for this purpose, and it will reveal that there is more data in the C3D file we just imported than we saw in lower extremity model.
Open the full body example model Plug-in-gait_Simple/FullBody.main.any. Please load the model and open a Model View if you do not already have one. You will see the model as before, but now with the arms included.
Model view Fullbody initial load
Select and run the Main.RunParameterIdentification in the Operations tree:
The model starts walking repeatedly over the force platforms including the arm motions while it tries to optimize segment lengths and marker positions. It takes 4 iterations and considerable more time than before to optimize the model because this is a much larger problem, but as before you can speed up the process if you switch off the update of the Model View window. It is possible to monitor the convergence of the optimization problem from a Chart window like this:
Chart view, Kin objective
Eventually, the optimization process terminates and you can switch run the Marker tracking and inverse dynamics (Main.RunAnalysis) and perform the analysis of the entire body including the muscle forces.
This full-body model with almost 1000 muscle fascicles takes considerable more time to analyze but will reward you with very detailed information about the function of the muscle system in gait as illustrated below.
Model view, full body inverse dynamics
This concludes the introduction on how to use motion capture data in a complex musculoskeletal model. The following three lessons show how to set up a simple model using motion capture data, while the final lesson of this tutorial is about problems that may arise with C3D files.
