Lesson1: Simple drivers¶
As mentioned above, we often have preconceived ideas about a system’s natural DoFs, such as abduction of the shoulder or flexion of the knee. In the case of the pendulum, we might get the idea that the natural DoF is its rotational angle away from its resting vertical position. And we can very easily drive the pendulum using this DoF.
The simplest mechanism of motion drivers in AnyBody is called
AnyKinMotion
. With Pendulum.any open in an editor and the model loaded,
please place the cursor in the editor window just below then ending
brace of the AnySeg Pendulum
definition. Then click the Classes tab on
the right-hand side of the editor window. Unfold the class list and
scroll down to find AnyKinMotion
. Right-click and insert an instance at
the cursor position:
AnySeg Pendulum = {
Jii = {1, 0.01, 1}/10;
AnyRefNode Origin = {
sRel = {0, 0.5, 0};
AnyRefNode P1 = {
sRel = {0, -0.5, 0};
AnyKinMotion <ObjectName> =
//RefFrames = ;
//Surfaces = ;
//KinMeasureArr = ;
//KinMeasureIndexArr = ;
//MeasureOrganizer = ;
//CType = ;
//WeightFun = ;
//DriverPos0 = ;
//DriverVel0 = ;
//DriverAcc0 = ;
//AnyKinMeasure &<Insert name0> = <Insert object reference (or full object definition)>; You can make any number of these objects!
//AnyParamFun &<Insert name0> = <Insert object reference (or full object definition)>; You can make any number of these objects!
The prototype of the AnyKinMotion
class is set up to allow several
different options. But the simplest of these is to directly specify
something to drive and a function to drive it with. So we start out by
giving the object a name and removing all of its content.
AnyKinMotion JointDriver =
Then we specify what to drive by making reference to the pendulum joint:
AnyRevoluteJoint &Jnt = .Joint;
Now we have specified what to drive, so all that’s left is to create a function to drive it with. AnyBody contains a number of predefined function types that you can find in the Classes Tree, for instance AnyFunPolynomial. As the name indicates, this is a polynomial function and it can have any number of coefficients. A common use is to drive motion either in a very standardized way, for instance with constant velocity or constant acceleration, or to drive a motion by data to which a polynomial has been fitted.
Try inserting the red part of the code below:
AnyFunPolynomial DriverFun = {
PolyCoef = {{0, 5, -0.4}};
In the matrix PolyCoef
, each row contains the coefficients for a time
function driving one degree of freedom. The revolute joint we are
driving only has one degree of freedom, so the matrix only has one row,
but it still has to be defined as a matrix rather than a vector, i.e.
with double braces at each end. The polynomial coefficients then come in
increasing order and define the following driver function:
To get higher polynomial orders, simply add more terms to the vector.
Now try loading the model. If you have followed the instructions, you should no longer get the warning that that model is kinematically indeterminate. It now has the same number of drivers as degrees of freedom.
Next, run the model. Select Main.MyStudy.Kinematics
from the Operations
dropdown menu in the toolbar, and click the “Run” button:
If you have a model view open, you should see the pendulum starting to move and accelerate as it rotates a little more than one round before the end of the analysis at t = 1 second.
The use of AnyKinMotion
objects to drive a model is in principle always
like this, but you can select any Kinematic Measure to drive, i.e. not
just a simple joint angle, and you can use any function derived from the
abstract AnyParamFun class to drive it with.
In lesson 2 we shall see how this same mechanism allows you to drive the pendulum by motion capture data.
Next lesson: Lesson 2: Using motion capture data.
