Lesson 6: Troubleshooting C3D files#
Occasionally you may experience problems reading C3D files and some of the common issues are treated below. But before we get to them, let us review a few facts about the C3D format. The C3D format is a public domain, binary file format that has been used in Biomechanics, Animation and Gait Analysis laboratories to record synchronized 3D and analog data since the mid 1980’s. It is supported by all major Motion Capture System manufacturers, as well as other companies in the Biomechanics, Motion Capture and Animation Industries, and there is a web site and community devoted to its maintenance: c3d.org.
The fact that the format is binary means that you cannot open a C3D file and read it unless you have a special reader. There are readers available at the c3d.org website, and most motion capture systems come with software that reads and manipulates C3D files.
The fact that the file format is old and also designed to work on just about every conceivable computer system means that it has a rather complex structure and that there are rigid and precise rules for the creation of C3D files. An unfortunate consequence of this is that the format is error prone in the sense that not all software systems create C3D files that live completely up to the standard. The AnyInputC3D class in AnyBody is designed to cope with most of the common deviations from the standard, but occasionally you may run into a problem. Here are some of the common problems and solutions:
I know my C3D file contains data, but I cannot see any markers moving anywhere in the Model View.
There are two usual causes for this problem. The first one is a scaling issue. Data in C3D files is often in millimeters while standard settings in AnyBody such as coordinate system sizes, marker sizes and such are scaled to fit to a human-size model in meters. If AnyBody reads a file in millimeters and interprets the result as meters, then the markers will be very far apart, and if you Zoom All in the model view, the markers may be so small compared to the viewed space that you cannot see them.
The remedy is to set the PointScaleFactor in the AnyInputC3D object to 0.001, for instance, in the case of data in millimeters.
The second frequent explanation is that a C3D file contains two data sections: one for raw data and one for processed data. By default, AnyBody creates markers based on raw data, but if your C3D file has been processed by other software prior to being read by AnyBody, then the other software may have moved the marker data to the processed section leaving you with nothing in your model.
Code example 2: C3DSettings.any#
//AnyInputC3D
Main.ModelSetup.C3DFileData = {
MarkerUseAllPointsOnOff = On;
which instructs AnyBody to read data from both the raw and the processed data sections.
I get an error message when I load the model.
Many things can go wrong when loading a C3D file, simply because the format of the file is relatively complex. The aim has been to make AnyBody tolerant of some of the more usual deviations from the standard, but sometimes things are irreparably wrong with the file and you will end up with an error message that ideally should give you a hint of what the problem is.
If you get an error message stating that the file cannot be opened, that it is not a C3D file, or that the file is corrupt, then you likely have to go back to your source and find out whether the data you have been given has somehow been damaged.
Another class of error messages deal with specific problems with the file, for instance that a required section or header is missing. This can mean that AnyBody does not have the necessary information to process the file and has to give up.
The markers I get in my loaded model have different names from what I expected.
When you have loaded a C3D file into an AnyBody model, the object can subsequently be browsed in the Model Tree in the left hand side of the screen. Markers in C3D files have user-defined names for easier identification, and sometimes you will find that the names you get in the AnyBody Model Tree are not the same as you defined in your experiment. There are two possible reasons for this:
The first reason is that AnyScript is a programming language and has rules about allowed characters in names. So if the marker names in the C3D file contain characters that have a special meaning, for instance * or +, then they are automatically replaced by a text string of the decimal ASCII code of the sign surrounded by underscores, for instance _42_ instead of *.
The second possible reason is more subtle. The C3D standard has a liberal length constraint (128 characters) on names of markers, but the experimental community often uses strings of just four characters to name markers, and this implicit convention has influenced some types of software to truncate marker labels to four characters. So, if you have named your markers MARKERRKNEE, MARKERLKNEE, MARKERSTERNUM and so on, and your C3D file somewhere in the pipeline from experiment to AnyBody passes through a piece of software that truncates the names, then AnyBody will be given a C3D file where all the marker names are truncated to just MARK. AnyBody will not accept non-unique marker names and therefore renames them automatically.
